Comprestion test results
Old Jun 17, 2009 | 12:39 PM
Tweaked's Avatar
Originally Posted by kraylon
well i did it on a warm engine this am and the resukts are:
cylinder #1 190psi
cylinder #2 190psi
cylinder #3 180psi
cylinder #4 190psi
These numbers are acceptable for 1.8T. They should build to this by the 3rd "puff." The first is usually the lowest. If it builds from very low to very high, you likely have worn rings. If it builds way past the 220 mark on the 3rd "puff," you've likely got some carbon buildup.
Old Jun 17, 2009 | 03:28 PM
Midniteoyl's Avatar
what does it mean if the numbers are low and you put a splash of oil in the cylider and it goes up on the compression?
Bad rings... the oil will temp seal them.
Old Jun 17, 2009 | 04:08 PM
kraylon's Avatar
Originally Posted by hiwords
i'd go to autozone and borrow their compression tester. you're readings shouldn't differ each time by 10-15psi. one the same cylinder and same tester
copy that ill be getting a different compression tester and seeing if the numbers match
I would let it crank over 5-6 times with the battery charger hooked up. I very well could have some carbon build up it is getting close to the time of the year that it gets a full seafoam treatment.
Harbinger
Mar 29, 2008 11:28 PM
mozzancolla
Mar 19, 2008 09:53 PM
Jits7
Jul 7, 2007 05:09 PM
twinturbomew
Apr 21, 2007 05:40 PM
keko2004
Oct 25, 2006 04:39 AM
