Control. For less. Special Pricing on H&R Springs and Sway Bars from AWE Tuning
Old Sep 9, 2014 | 02:16 PM
Andrew/AWE's Avatar
Former Sponsor
Default Control. For less. Special Pricing on H&R Springs and Sway Bars from AWE Tuning
Power without control is nothing. H&R Springs and Sway Bars bring in checks and balances to the power AWE Tuning can unlock from your Audi.
For a limited time, H&R Springs and Sway Bars are 10% off at AWE Tuning. Get in control... here.
Old Sep 12, 2014 | 09:54 AM
Andrew/AWE's Avatar
Former Sponsor
Form and Function. With AWE tuning's special pricing on H&R Springs and Sway Bars, you can have performance without compromise. H&R Springs/Swaybars | AWE Tuning
Old Sep 13, 2014 | 11:53 AM
A4TurboGuy's Avatar
Here's my problem:
I just replaced my steering rack, inner tie rods, outer tie rods, all ball joints, all 4 upper control arms, and all 4 lower control arms. I also installed the ECS Ultimate timing kit, HD clutch & flywheel.
The only thing I didn't do is coil-overs.
I went to have it aligned, and although they could align the toe, they couldn't adjust camber, or caster - Apparently every single alignment shop in my area doesn't know how to align a quadra-link suspension (even though it's only 8 bolts to loosen).
After the "alignment", my car still has negative camber ON BOTH front wheels and it pulls to the right (on new tires).
I was thinking about adjusting the sub-frame myself, when it dawned on me: "How in the hell can I possibly have negative camber on both front wheels?.......especially when everything is stock/oem replacement?
Adjusting the sub-frame will fix one side, but make the other side worse.
Also: How in the hell is this thing pulling to the right when the toe is correct on all four wheels and all of the tires have the same (32psi) pressure?
I am completely dumbfounded here.
Can you help?
Thanks!
Old Sep 14, 2014 | 01:00 PM
Andrew/AWE's Avatar
Former Sponsor
Originally Posted by A4TurboGuy
Here's my problem:
Can you help?
Thanks!
PM Sent
Old Sep 15, 2014 | 05:56 PM
Andrew/AWE's Avatar
Former Sponsor
Control the roll. H&R Sway bars are the answer to any roll issues. With AWE Tuning's special pricing on H&R Springs and Sway Bars, you can now unlock performance for less. H&R Springs/Swaybars | AWE Tuning
Old Sep 16, 2014 | 11:08 PM
Sp00led's Avatar
Default I'm having a similar alignment issue
Originally Posted by Andrew/AWE
PM Sent
Having a similar problem with my 2000 A4's alignment so it would have been nice to see the posted reply.
Looking for some help trouble shooting and advice on where to go from here.
Thanks!
Old Sep 17, 2014 | 08:23 AM
A4TurboGuy's Avatar
Mine ended up being severe radial pull on one of my new tires. I had the tires rotated and the problem was instantly resolved.
Old Sep 17, 2014 | 09:41 AM
Andrew/AWE's Avatar
Former Sponsor
Handling, handled. Special pricing on H&R Springs and Sway bars from AWE Tuning. Get yours here.
Old Sep 19, 2014 | 04:14 PM
Andrew/AWE's Avatar
Former Sponsor
Less is more. Reduce body roll with AWE Tuning's special pricing on H&R Springs and Sways. H&R Springs/Swaybars | AWE Tuning
