Coolant question
Old Jan 24, 2013 | 12:45 PM
Gusset's Avatar
Default Coolant question
My recently purchased A4 has green coolant. I'm considering flushing it and replacing it with G12. If I do, I want to be thorough and avoid mixing the different coolant formulas. Searching on this site, folks sometimes recommend doing a "chemical flush" for thoroughly cleaning out the cooling system. Is there a specific product that is recommended for doing a chemical flush on an Audi?
Thanks for any help.
Old Jan 24, 2013 | 12:53 PM
ECS Tuning's Avatar
Sponsor
We recommend DEI Radiator Relief Flush. Check it out below.
Click HERE to order or for more information.
Jason
Old Jan 24, 2013 | 01:45 PM
CCA4's Avatar
The previous owner of my car mixed regular coolant with G12 and it turned to peanut butter. 3 expansion tanks and four coolant system flushes later and it still isn't right. I've been told that draining all of the coolant, then refiling with plain distilled water, run the motor for a few minutes to circulate it, then draining again is the best way to go. Repeat until the distilled water comes out as clean as it went in, and then fill it with 50:50 G12/distilled water.
Old Jan 27, 2013 | 04:23 AM
MrSnickelsnizer's Avatar
Definetly what he said. You need to flush the system out, so keep filling with distilled water and running then emptying till all is clear. Get the green out!
Old Jan 27, 2013 | 09:15 AM
ImTheDevil's Avatar
There is a block drain somewhere on the engine - find that and drain from there as well as the radiator each time, so you know you're getting it all out. CCA4 is correct with the procedure. Make sure to run the heater while doing this so you clear the heater core as well.
Old Jan 27, 2013 | 02:26 PM
redline380's Avatar
Legal Moderator
you can run the green coolant all you want. if the previous owner did a good job of flushing it, go ahead and keep it in there. but as the others said, if it was mixed, get it out of there ASAP.
eddiefury
Nov 9, 2008 07:34 AM
bkcox_S4
Jul 3, 2008 01:56 PM
Armenian
Jun 22, 2007 06:29 PM
a4anonymous
Sep 26, 2005 06:56 PM
skull10
Jan 16, 2005 01:04 PM
