coolant tank
Old Nov 6, 2008 | 04:24 PM
TeeterTawter's Avatar
Default coolant tank
My coolant tank has a **** load of spider cracks in it causing it to leak a bit, Where do you guys get the white ones, all i am finding are the yellow urine coloured tanks.
thank you
Old Nov 6, 2008 | 05:21 PM
onepoint8tee's Avatar
You can get a B6 coolant tank but make sure the sensor plug on the bottom fits. It should since you have a 2000, but I know for a fact that the 96-99 plug would not.
Old Nov 6, 2008 | 07:35 PM
Redrum1's Avatar
This is where I bought mine. Listing for your car is:
http://www.autohausaz.com/search/pro...nt%20Reservoir
Good Luck...
Old Nov 6, 2008 | 08:16 PM
relliMmoT's Avatar
i think i got mine from ECStuning.com . I had the very same problem. I am replying just to suggest getting the coolant expansion tank cap from ECS for like $5 bucks, i read that its oober common for the black vent valve thing in the middle of it to break off the cap- happened to me.. every time i took the cap off it would leave that thing lodged in the tank and i would have to pry it out with a screwdriver. $0.02
Old Nov 6, 2008 | 09:31 PM
Thank you everyone for your responses
Old Nov 6, 2008 | 11:45 PM
ImTheDevil's Avatar
Do you know if the B6 plug can be used in the 96-99? Even if the connector has to be re-pinned to make it work? I'd love to get the white tank in my pre-facelift 99 if at all possible.
Old Nov 7, 2008 | 12:29 AM
Tweaked's Avatar
The white one is the updated tank. If you get one over the counter from an Audi dealer, it should be the white one.
Old Nov 7, 2008 | 12:30 AM
ty98a4's Avatar
iam also interested in this, as mine looks like crap...
Old Nov 7, 2008 | 03:12 AM
qUaTtRoA4's Avatar
got mine at ecs...it is bright white and a direct replacement....
gl!
DennisGa
Oct 26, 2014 05:43 PM
twinturbosixer
Apr 24, 2009 01:41 PM
gquin1
Mar 25, 2009 11:53 PM
speedmetal1
Apr 2, 2008 06:48 AM
to3o
Nov 5, 2007 02:12 PM
