could a blocked oil passage.....
Old Feb 7, 2012 | 02:11 PM
patty36j's Avatar
I replaced the cam it started up everytime but ran like **** i then retuner the throttle body. And it ran fine i also replaced the crank position sensor. Drove for a few hours and just started to randomly stall again. Eventually it just didnt start....replaced the throttle body started right up didnt drive it just let it idle. Came up wit like ten codes for a cam position sensor and a throttle body codes.
Sorry if i seem nieves i just have no clue wat else to replace or where else to start from
Old Feb 7, 2012 | 02:53 PM
patty36j's Avatar
P1531 P0011 P1545 P1543 P1172 P1564
Thats the codes that recently came up
Old Feb 7, 2012 | 03:12 PM
patty36j's Avatar
P1564- idle speed control throttle position low voltage during adaption
P1297- connection turbocharger throttle valve pressure hose
Also these
Old Feb 7, 2012 | 04:52 PM
M5S5's Avatar
Tech Certified
You still have not mentioned what engine you have?????????????????
Old Feb 7, 2012 | 08:39 PM
patty36j's Avatar
Awm it says
Old Feb 8, 2012 | 10:50 AM
M5S5's Avatar
Tech Certified
You could have a voltage supply problem.
What is your battery voltage?
Check power at cam sensor & at throttle.
Old Feb 8, 2012 | 12:37 PM
patty36j's Avatar
Alot of my codes say that...wat would do that?
Old Feb 8, 2012 | 01:23 PM
  #18
M5S5's Avatar
Tech Certified
You did not answer the previous questions yet!
Just trying to help but need more info. A silver bullet i can not provide!
Old Feb 8, 2012 | 04:06 PM
  #19
patty36j's Avatar
Lol im at work right now sorry i get codes that its low voltage. Battery brand new cam is brand new an so is the throttle ill try and get the voltages tonight but i got a game so ill have to do it tommarow. Stay posted!...what would causr a low voltage to them though?
Old Feb 8, 2012 | 04:28 PM
  #20
M5S5's Avatar
Tech Certified
Battery voltage is?????
New = never ever worked! What is the actual voltage?
The cam is new! Did you mean cam sensor. If you are getting voltage too low faults it is imperative that we know the voltage going to the sensors & battery voltage.
Sorry for being blunt about the questions but if you are not capable of answering it should go to a professional who can or you will end up broke throwing parts at your car.
