Could this be the cause?
ORIGINAL: shady927
so it is a soft code but has some repercussions... Running too lean means too much air in the system, u need the right balance or stuff like what u r experiencing happens. Take it to autozone have them hook it up to there OBD II and see what other codes are on there
ORIGINAL: shady927
I thought autozone used a Modis???? Guess not, yeah those Modis' are the ****
Thats weird cause my A4 been doing the same thing to me too. I have a VAG OBD II reader and it keeps popping up with a "17536 Fuel Trim: Bank 1 (system too lean) p1128". This popped up after i fitted it with a carbino intake, and when i put the stock box back in the car still throws me a lean code. I got the intake from my friend who gave it to me cause he wrecked his a4. The code keeps poping up and its driving me mad cause it makes me run at safety boost or "limp mode". It also for a while before i cleaned the MAF gave me a "16891 Idle Control System RPM: Higher than Expected". any thoughts anyone? O i have a 2001 A4 1.8t Quattro 5-speed Stick.
i get codes from this whether or not the CEL is on. it reads them, and i know what running lean is. i have been hunting this problem for a while
Also, the temp guage never fully hits the middle, allways just before it or farther, which could imply running ritch. (lean runs hot rich runs cold)
also, the exaust pipe has a fair bit of carbon in it, again would imply rich.
Looking at those, my best guess is still the secondary air injection as it could make the CAT think its too lean and the computer will try and compensate by adding more fuel, giving me the carboned exhaust, the running cold, and the missfires.
