Couple of questions regarding replacing 2.8 valve cover..
Old Sep 25, 2012 | 10:46 AM
kduznetsov's Avatar
Default Couple of questions regarding replacing 2.8 valve cover..
Well I plan on doing this this weekend, I'm not going to be taking off the front end because I'm clueless of the serpentine belt timing. So I'm just removing my intake, all the engine covers, and going to town. A few questions, if I'm not mistaking the cylinder coils are just removed by yanking up on them? Also I read I need to tighten the bolts to 7lb, which tool can I use for this? Do I really need it?
Old Sep 25, 2012 | 11:12 AM
audinoob27's Avatar
Serpentine belt timing?!?! Stop don't take anything apart lol
Old Sep 25, 2012 | 02:31 PM
kduznetsov's Avatar
ahaha.. it was really early when I wrote this, I've taken apart most of my engine before, i changed the timing belt myself, I just had a friend position it. Obviously I'd rather not go through the whole process again.
Old Sep 25, 2012 | 08:06 PM
jonbonesjones's Avatar
Moderator
your whole first post is scary D:
dont take off the intake to remove the valve covers. Pull the plug wires {not coils} and use a ten mm wrench there's 8 nuts on each one. remove the other few things in the way, that's all you need to do.
mgmarceau
B7 Models
Nov 12, 2014 12:19 PM
bryan0
Mar 11, 2011 10:21 AM
AutoUnionFan
Jun 8, 2009 12:10 PM
whitejeepXJ
Apr 7, 2008 07:52 PM
