Crank No start
Old Mar 25, 2016 | 07:41 PM
ChaseNFF's Avatar
Default Crank No start
I have a 99 audi a4 2.8 and I cant seem to get it too start. I know its a fuel problem but i cant seem to pinpoint what the problem is! I have replaced the fuel pump, the fuel filter, the fuel pressure regulator, the relay. I have even looked at the fuses and still nothing. It seems like a pressure issue as im only getting half of what I should. I took it too a mechanic that says that a fuel line is bent up and not allowing to let gas get through. Im currently working on that and hope it fixes it however im not too trusting of what he is saying. Is there anything else I can go through to see what is going on? This happened after about a hour and a half drive took it home went to bed went out the next morning and it would not start(it was dead) so I replaced the battery because they told me it was bad and now it just cranks over and over. I have looked and know that im getting spark. I also have replaced the spark plugs the valve cover gaskets(lots of oil in them) the battery again changed the oil etc im running out of ideas and was hoping someone here could give me some ideas of what might be happening if you need any more info let me know thanks!
Old Mar 25, 2016 | 07:42 PM
ChaseNFF's Avatar
I also have taken Vag-Com and realigned the throttle body because i was getting a code for it.
Halfpint2209
Apr 22, 2019 08:42 AM
SHAYs4
Nov 28, 2010 02:01 PM
jbangsund
May 13, 2010 06:36 PM
Shizzle
Apr 7, 2007 08:31 PM
