Crunchy Gears
Old Jan 30, 2009 | 08:26 PM
mzo0163's Avatar
Sounds good, Ill check my fluid level and see if its low. I dont feel too confident in changing it though if it may not help or if it could make things worse. Thanks for the help
Old Jan 30, 2009 | 09:32 PM
SAudi's Avatar
its the synchros over time they just wear out and older cars they crunch until the gearbox heats up a bit, i had the same issue and theres 2 things you can do, double clutch until the gearbox heats up (1-5 minutes) or replace teh gearbox oil with gm synchromesh to quite down the gears (30 minute drain and fill)
Old Jan 30, 2009 | 11:29 PM
chaos92287's Avatar
it cant make things worse and opening the tranny up will just confirm its the synchros. 99% of the time, when only 1 gear grinds, its the synchros. to be sure, double clutch it from first to second and see if it grinds. it shouldn't
Old Jan 31, 2009 | 09:31 AM
compmanben's Avatar
It's a pretty common problem - happens on my car and my dad's.. worse on mine though. I tried changing the fluid and I even took it to a transmission shop - they checked it out and nothing was wrong / synchros were OK. So - that being said, I just live with it.
Old Jan 31, 2009 | 01:02 PM
chaos92287's Avatar
then that transmission shop sucks. gears dont just grind for no reason. the clutching teeth on the idler gear could have been worn down, but the syncros were fine.
Old Jan 31, 2009 | 06:05 PM
Tweaked's Avatar
Yes, agreed. ahaha
Old Jan 31, 2009 | 06:54 PM
Audacity's Avatar
i don't know man, i've got the same thing, i just rev it up a little more than any other gear when i shift. that seems to make it better but its only a matter of time
Old Jan 31, 2009 | 09:06 PM
  #18
nova_ss672001's Avatar
mine does the same thing, only when its cold and haven't warmed it up completely, after its warm and/or go through 2nd gear like twice it goes away? and don't happen again until the next day in the morning again...?
but i have read that you have to give the tranny fluid time to warm up before, it will let you shift smoothly?
Old Jan 31, 2009 | 09:38 PM
  #19
mrbloink's Avatar
I have the exact same problem. when the engine has warmed up it is fine and shifting is really smooth. In the sumer i never felt any crunchiness. I figured it was no problem and its just because the fluid is cold
dubadxx
Apr 1, 2010 11:29 PM
A4todamax
Jan 23, 2007 05:15 PM
KoFi
Mar 27, 2003 06:31 AM
