cylinder 2 misfire!!!! help
Old Feb 22, 2008 | 01:36 PM
ricky0323's Avatar
Default cylinder 2 misfire!!!! help
i was driving back from work and as i parked the car to stop and get some snacks, when i cam back the car was sputtering and i have no power, sacanned it and PO302 came out as a cylinder 2 misfire, what are the steps to take to figure out what of the many things that can be wrong with my car
by the way does it have anything to do with my fuel tank being almost empty when that happened?
could it be an injector?
please help me out on this one!!!
Old Feb 22, 2008 | 01:46 PM
auditech79's Avatar
Default RE: cylinder 2 misfire!!!! help
What year and what engine do you have?
Old Feb 22, 2008 | 02:19 PM
cincyTT's Avatar
I'm make believe
its either the plug or coilpack. IF you swap the coilpack to a differnt cylinder and the code follows it, its the pack, if it doesnt, its the plug.
Old Feb 22, 2008 | 02:21 PM
Leifer's Avatar
You can also measure the resistance in ohms via a .... ****, I forget what it's called.
Anyways yeah, the most common problem is spark plug / coilpack failure.
Old Feb 22, 2008 | 02:33 PM
cincyTT's Avatar
I'm make believe
volt meter [8D]
I love having one. Makes life easy
Old Feb 22, 2008 | 05:47 PM
ricky0323's Avatar
ok so here is what i did i disconected the coilpack from cylinder number two and switched it with cylinder number one and the coilpack from cyl 2 works perfectly on number one but the coilpack that was working stops working, there is no current from the plug or the cable.
steps to follow??
by the way its a 98 B5 1.8t manual
Old Feb 22, 2008 | 05:57 PM
cincyTT's Avatar
I'm make believe
Then it must be a problem in the coilpack wiring harness. You are going to have to find the wire that has most likely been melted
Old Feb 22, 2008 | 06:16 PM
auditech79's Avatar
No need, if its a pre-00 you need a new ICM. Swapping coils and spark plugs won't do s***t.
Go to www.ecstuning.com for a new one. Its the thing sitting on top of your airbox.
Old Feb 22, 2008 | 11:07 PM
Lazer Viking's Avatar
ORIGINAL: auditech79
ding ding ! winnar
Old Feb 23, 2008 | 11:34 AM
ricky0323's Avatar
im going with the icm problem, because it seems like the simples way to go, my question is this is it bad for me to run the car with this problem i know im wasting a lot more gas, but unfourtunetly school doesnt let me take a break while i am able to order this part and fix it!!!!!!!
