cylinder 2 misfire problem?
Old Aug 4, 2008 | 11:21 AM
NerminM87's Avatar
Default cylinder 2 misfire problem?
whats up guys, im having trouble with my 97 audi a4 quattro, i went to autozone and they told me that i have a cylinder 2 misfire, they said to replace the spark plugs and if that doesnt fix the problem to replace the coil pack, i did both and im still having the problem, the engine light is on, and the car is shaking alot, the engine is too loud, before this problem i could barely hear the engine...
thanks in advance guys
Old Aug 4, 2008 | 11:24 AM
onepoint8tee's Avatar
Please dont listen to autozone hippies...
You should have first swapped the coil pack from the cyl that is missing to a different cyl to see if the miss follows the coil pack. Since that didn't work, and spark plugs are ok, it's gotta be your ICM/ignition amplifier. It's located on top of the airbox. Very common to get a cyl 2 miss when that goes bad, and they DO go bad. The ICM controls your firing order, unlike with newer 2000+ cars the firing order is controlled by the ECU which eliminates the ICM. I think you can find one on ebay for real cheap compared to the dealer or even autozone.
Old Aug 4, 2008 | 11:44 AM
aRIf's Avatar
I have brand new ICM for sale if you want to buy
Old Aug 4, 2008 | 11:53 AM
NerminM87's Avatar
thanks onepoint8tee, i have been tryin to find it online, but no luck so far...
arif how much r u sellin it for , u got pics of it?
Old Aug 4, 2008 | 01:23 PM
arif is ALLLLIVE! Welcome back.
Old Aug 5, 2008 | 01:56 PM
aRIf's Avatar
I'll get you pics and serial numbers tonight.
i think I paid $180 or something but I can give you great deal because I do not need it.
Looks like this;
I'll get the serial number tonight and post it in here.
haha Thanks Jason.
Old Aug 5, 2008 | 08:03 PM
aRIf's Avatar
Actually the serial number is as same as the picture above
Bosch
0 227 100 211
Let me know.
Russ Heinrichs
Aug 18, 2021 12:39 PM
ikoflexer
May 24, 2012 08:25 AM
ivantheterbl
Nov 6, 2011 12:55 PM
austindgarner
Jul 1, 2008 10:48 PM
