Cylinder 2 missfire + Multiple/Random Cylinder
Old Apr 10, 2009 | 06:43 PM
DjSly's Avatar
Default Cylinder 2 missfire + Multiple/Random Cylinder
So here is the deal,
My Car is : Audi 98qmt B5
I have these two codes:
16686 : http://wiki.ross-tech.com/index.php/16686/P0302/000770
16684 : http://wiki.ross-tech.com/index.php/16684/P0300/000768
I tried the following,
1) I swaped the coil for #2 and #3 , I received ther same code: Cylinder 2
2) I swaped the sparkplug for #2 and #3 , I received ther same code: Cylinder 2
3) I swaped the injectors for #2 and #3 , I received ther same code: Cylinder 2
Now I don't know ... What should I check after that ??
It all started randomly yesterday while I was in traffic
Really it doesnt look like a easy job anymore
Any input would be appreciated
Thanks
Old Apr 11, 2009 | 12:18 AM
hiwords's Avatar
it's your ICM
Old Apr 11, 2009 | 03:00 AM
DjSly's Avatar
sry for my ignorance but what is an ICM and where is it located ?
thanks
edit: ICM - ignition control module, still couldnt find the location
Old Apr 11, 2009 | 05:05 PM
DjSly's Avatar
I tested the ICM today...
I checked the resistances and they were all around 230ohms.
I couldnt find a test LED to make sure the frenquencies were ok ...
Old Apr 28, 2009 | 01:25 AM
elrocha69's Avatar
I say the ICM as well. I would try unpluging the injectors one at a time. the one that doesn't make a difference is the cylinder that is misfiring. check to see if that injector is firing. If it is and swapping the coils do not make any difference the ICM is bad. It is very delicate inside. the tiny wires break and do not make contact. I pushed and twisted my ICM and it mysteriously started back working. It is located on the air filter box and has 2 plugs going to it. It is held on by 2 8mm bolts. pull the plastic decorative cover off an itll be right there.
bigozzyfan4life
May 20, 2013 10:18 PM
Maxmillion
Apr 8, 2011 12:26 AM
Mr. Phil
Jun 24, 2010 10:13 AM
audia4boy24
Jul 24, 2008 01:33 PM
dj_lex
Nov 5, 2007 08:03 AM
