Dam P4011 CODE wont go away.
Old Sep 13, 2010 | 01:00 PM
MiamiA4guy's Avatar
Default Dam P4011 CODE wont go away.
This dam P4011 code is the only thing that's stopping my baby from being perfect lol and I have done some research and i kno it's the secondary air pump but what the hell does that pump do?? and how do i fix it?? any help will be apprciated guy's thanks.
Old Sep 13, 2010 | 01:05 PM
copper07's Avatar
I have fought this code and mine keeps coming and going. The trick I have seen that works for lots of other people on the forum is to check all the little vacuum lines and change them to make sure you don't have an air leak. The secondary air pump runs when the car is started from a cold start, I think it is for emissions.
Old Sep 13, 2010 | 01:24 PM
colony777's Avatar
it is only for emissions, its useless. i wouldnt even worry about that code if i were you. im sure a bad 02 sensor could cause that code too
Old Sep 13, 2010 | 01:48 PM
copper07's Avatar
I think if there was a bad O2 sensor that there would be more than one code.
Old Sep 13, 2010 | 02:26 PM
colony777's Avatar
but wouldnt you think that if his SAI wasnt working hed have more than one code anyway? SAI is to counteract the rich period during a cold start. the 02 sensors SHOULD throw codes that its running rich, IF the SAI isnt working.
Old Sep 13, 2010 | 02:56 PM
Msnickbroderick's Avatar
Actual WIZARD
See if there are debris in the screen before your airbox. Thats what caused mine, and it was random as well
Old Sep 13, 2010 | 03:11 PM
MiamiA4guy's Avatar
I cleaned my MAF like 2 weekend's ago and did my air box mod and there was no debris so i will try to replace all my vacuum hoses does any one kno where i can buy some at like a local place that i can pick up on my way home?? Becuase really the only time that i have to do any car work is during the weekend due to school and work.
Old Sep 14, 2010 | 12:42 PM
shortyxc's Avatar
Take out your secondary air system. you don't need it anyway.
waffles7622
Feb 14, 2013 04:59 PM
adman89
Oct 30, 2012 06:01 PM
tatensty
Sep 12, 2008 04:38 PM
Daniel P
Jan 6, 2007 06:32 PM
