Dash Question?
Old Apr 24, 2008 | 05:48 PM
ceelos's Avatar
Member
Default Dash Question?
Hello All,
I have a 98' A4 Avant and was wondering if there is a way to turn on or offthe the two thin long displays in the dash. Please see the pics. I search and couldn't find anything specific and was wondering if the display is just not working. Thanks in advance.
http://i33.photobucket.com/albums/d5...4242008209.jpg
http://i33.photobucket.com/albums/d5...4242008211.jpg
http://i33.photobucket.com/albums/d5...4242008212.jpg
Old Apr 24, 2008 | 05:56 PM
1.84life's Avatar
Default RE: Dash Question?
button on the bottom of the window washer arm
Old Apr 24, 2008 | 05:59 PM
ceelos's Avatar
Member
My car doesn't have the little button under the window washer stalk. I did look for that cause my 01' has it.
Old Apr 24, 2008 | 06:00 PM
1.84life's Avatar
then you either cant do it or i just dont know..there might be a seperate fuse just for that part of the cluster you can pull if no one else has an answer
Old Apr 24, 2008 | 06:02 PM
ceelos's Avatar
Member
thanks 1.84life
Old Apr 24, 2008 | 06:23 PM
Redrum1's Avatar
If your car is a manual transmission the top one is for the automatic gear read out. The bottom row is the outside temperature read out. So maybe in your model those weren't used. Just like when I got front pads this past weekend. They asked if my sensor wires had a round or oblong plug and I told them I would cut the wires off cause they weren't used on mine. Nothing on the stalk on mine either.
Good Luck...
Old Apr 25, 2008 | 06:23 PM
ceelos's Avatar
Member
I know what you mean. Thanks for your help Redrum1.
Old Apr 25, 2008 | 06:50 PM
ImTheDevil's Avatar
Yep, my manual trans car doesn't use the upper display, but my lower one is for outside temp. On occasion, there've been times that I started the car and it didn't light up. Most of the time it worked. Each time that it didn't, it would return the next time I drove the car. It's just a flaky part I think.
dolceto
Mar 24, 2014 09:55 PM
C5turbo
Oct 12, 2011 04:48 PM
boomshine
Jul 5, 2008 03:27 AM
nathaniel.darling
Oct 21, 2007 12:16 PM
bliggity
Aug 5, 2005 02:17 PM
