Dead in the intersection
Old Sep 1, 2011 | 03:06 PM
supergoober752's Avatar
Default Dead in the intersection
was on my way fishing this morning, sat at a red light and my car idle started to dip below 1k and back up. put the brake on and revved. seemed fine, soon as green hit the car died and fed ex helped me push it into the gas station. I got the coils recalled 2 days ago and it ran strong since. it will turn over but not start. very confused. called the dealer and they said its not the coils nor their falt those basterds.
Any ideas while my cars sitting at the shell?
edt: shot the code P0010 bank circuit malfunction camshaft position actuator A. where is that sensor?
Old Sep 1, 2011 | 03:58 PM
jonbonesjones's Avatar
Moderator
It's on the head where the cam comes out replace it your car should start
Old Sep 13, 2011 | 09:20 PM
low and behold, replaced the sensor and it still doesnt start, any suggestions? this is killing me! such a small part to make a car not work
Old Sep 28, 2011 | 04:22 PM
adamlouks's Avatar
Coolant temp sensor
Old Sep 29, 2011 | 11:31 AM
jdahlen24's Avatar
Yeah, it could be the coolant temp sensor has gone south and is causing the ECU to dump too much fuel into the engine.
Try cranking it over while holding the accelerator pedal all the way to the floor.
Old Sep 30, 2011 | 12:58 PM
Turns out it was the relay for the ecu. Easy $10 part. Took hours of researching. Could have been anything really. Thanks for the help
Old Sep 30, 2011 | 05:15 PM
Aud1A4's Avatar
im glad it worked out for you
thorjov
Nov 4, 2015 09:19 PM
sujoyron
Oct 4, 2014 01:56 PM
tom.beckman
Sep 2, 2013 10:19 AM
jbooker
Apr 30, 2009 10:09 PM
