Did I just mess up a timing belt job?
On my 2001 AWM (late model), I THINK I made a mistake...
I pulled the pin in the tensioner with the tensioner pulley not fully holding the timing belt tight. The tensioner relesaed the spring loaded pin (it shot fully out) and the gap between the lever on the tensioner pulley and the tensioner housing is significantly greater than the recommended 8mm (it is several inches).
Is there a way to reset the pin? If not, do I need to order a new tensioner?
The tensioner design seems retarded if it can be messed up this easily.
Done. Had to take the assembly to pepboys. They put it in their metal vice and i stuck the pin back in. Haynes is terrible - it says to pul the pin first - I'm burning that book.
Thanks for your advice.
Audiguruforyou
Sep 20, 2011 01:31 AM
Jeffla
Jan 3, 2010 04:43 AM
fritz
Aug 12, 2007 02:55 PM
