A different Steering problem...
Old Nov 21, 2008 | 03:23 PM
Schwalbe181's Avatar
Default A different Steering problem...
I thought that my pump was bad but i think its just from the cold, both days its done it at different times, and randomly, but both times it was pretty cold, and after driving it warmed up and was fine. But now today when i was bcking into my house, i realized that when i turn the wheel when just coasting on gear in reverse, that the revs drop when ever i turn the wheel from straight. They drop to about 600 then back up to 900 if i stop turning. Could this be applying more stress on the pump causing the engine to drop its revs? Whats up? Thanks.
Old Nov 21, 2008 | 07:09 PM
compmanben's Avatar
Perhaps check what color your fluid is - it should be a green, thin fluid. You might have a thick fluid in there that's making the pump work too hard.
Old Nov 21, 2008 | 10:57 PM
SAudi's Avatar
did you replace the fluid, like i said it wears out over time and you need to replenish the mineral additive crap in it. i had the same issues and it turned into a steering rack issue.
Old Nov 21, 2008 | 11:53 PM
ill take a look at it this weekend, it looks a little thick but im not sure what its supposed to look at to begin with. but ill see if any of my buddies can shed some light on it. Thanks
gold2734
Sep 3, 2009 08:58 PM
Lastb0isct
Feb 17, 2009 03:15 PM
99'A6
Sep 26, 2008 08:35 AM
B5nightrider
Oct 3, 2005 03:34 PM
mitao2000
Feb 8, 2005 02:41 PM
