Diverter/Blow Off Valve Information
Old Apr 26, 2008 | 09:15 PM
chaos92287's Avatar
Exclamation Diverter/Blow Off Valve Information
I was helping a member with his DV install and then just decided to put that and some other things into a thread.
I didn't have a DV so i had to use a pic off the internet
This is how it looks on a stock AEB (96-99.5). I'm not certain when they switched it, either 00 or 01, but it is the same way, except the DV is on the on the other end of the hose like showed in this pic
and here's a diagram of it
So instead of the DV sitting in the TIP, it is sitting in the turbo outlet hose.
And here is how to install a BOV
And in case you're wondering where the vac line goes. It goes to the intake manifold, same as stock. You can see it in this pic. This is also the same line you place a T in when you install a boost gauge or MBC/EBC
And in case you're wondering how the n75 is supposed to be installed
The pulleys and belts
[ol][*]Tensioner[*]Alternator[*]Viscous Clutch[*]Water Pump[*]Power Steering Pump[*]Water Pump Belt[*]Main Accessory Belt[*]Crankshaft Pulley[*]Tensioner[*]A/C Belt[*]Air Conditioner Compressor[/ol]
Vacuum Diagram for DBW a4's. (To help diagnose those pesky vac leaks)
Vacuum diagram for the 12v- http://www.12v.org/maintenance/index...=tr&ss=vac
i'll add more when i think of more
Old Apr 26, 2008 | 10:28 PM
mr.cAp's Avatar
Default RE: Informative post on the AEB
can we get a sticky on this please,
Old Apr 27, 2008 | 12:10 AM
audiejohn's Avatar
Member
Thanks a bunch chaos, now I understand a little how everything works since I can see all the internals!
Old Apr 27, 2008 | 03:43 PM
audiejohn's Avatar
Member
One question about the Forge 004, Is it true that we are loosing HP when we install an atmospheric BOV on our B5s?
Old Apr 27, 2008 | 06:18 PM
chaos92287's Avatar
nope not losing any power
Old Apr 29, 2008 | 08:55 PM
CIA's Avatar
CIA
hey chaos,
Where can i get all the diagrams of the car?
Old Apr 29, 2008 | 10:01 PM
chaos92287's Avatar
vagcat has some but when i try and click on others it tells me i have to be a registered user, even tho im already a registered user. so i dont know whats up with that. im pretty sure the bentley cd has them as well
Old Apr 30, 2008 | 02:57 PM
jago's Avatar
thanks alot for the post man!
Old Apr 30, 2008 | 11:11 PM
Nick_UltraSport's Avatar
you are awsome bro
Old May 7, 2008 | 09:56 PM
audiejohn's Avatar
Member
Hey Chaos, I got another question, I purchased a Forge Splitter and I have it programed as a Hybrid. It said that I have to have the valve set up the other way from the Bosch DV. So I "borrowed" your pictures and did my photoshopping myself :] This is how I installed my splitter.Name:  Splitter.jpg
Is that the RIGHT way? If it is, that's awesome, took me a while to install that, I was just wondering because sometimes I feel that the turbo is not pulling enough when it hits 3000rpm compared to when I have the stock DV, could it be that I just have to tighten the spring on top? Thanks in advance!
