Diverter/Blow Off Valve Information
Old Aug 7, 2009 | 01:39 AM
  #21
ghost6303's Avatar
Originally Posted by a4one
<img src=".....">
I can't seem to figure out what this piece is. mines is broken, and i've been trying to buy this item for a while now. please can anyone give me the name of this item.. thanks
im going to say a check valve but i dont know because you wrote over the whole schematic so i have no idea where that is going to or from. good game.
BOVs tend to be more trouble then they are worth on a stock engine. you have to get the correct type and adjust it correctly, otherwise your car will run like crap. just stick to a DV you dont need to flow that much air anyways.
Old Aug 30, 2010 | 06:15 PM
  #22
netoLopez's Avatar
Red face
I see, this what i should of checked in the first place. i feel like a dumb ***
Old Aug 30, 2010 | 07:07 PM
  #23
joenelson7687's Avatar
Wow...reviving a dead thread. Thanks for searching and not being a total 100% undeniable complete NOOB
Old Aug 30, 2011 | 09:53 PM
  #24
PWagg's Avatar
Ok so are there two kinds of diverter valves? Kinda confused. There are the ones like the forge splitter that you hook up to the two hoses and then there are ones that are electronic like this?
Audi B7 A4 Quattro 2.0T > Engine > Intake > Diverter Valve > ES#263879 Upgraded Piston Diverter Valve, Electronic - 06H145710D
Im new to turbos so i dont really know much. Thanks guys.
Old Aug 31, 2011 | 12:02 AM
  #25
CCA4's Avatar
The link you posted is for the 2.0T FSI motor. Not applicable in any way to our cars.
Old Aug 31, 2011 | 01:49 PM
  #26
Emilgevor's Avatar
Pretty confused my self right now?
As far as I know its is not recommended to run BOV on our cars. We should be running DV and have pressure recirculate back into the spooling turbo.
Correct me if im wrong but BOV will cause bigger turbo lag between shifts and overtime can cause our turbos to fail prematurely?
Old Jun 17, 2012 | 12:26 AM
  #27
J_PEZ's Avatar
use for the n75? Will this increase boost just by adding it? Does the ecu have to be set at higher boost for this to work? Im used to just useing a boost controller
Old Jun 17, 2014 | 09:20 AM
  #28
GreenMachine22's Avatar
Any advice on which blow-off valves to purchase? Bought one once and it was a piece of crap. Thanks.
george1546
Apr 20, 2014 04:12 AM
Connor Schleicher
Nov 8, 2011 07:13 PM
funkymillah
Dec 3, 2007 03:20 PM
EliteTuning1
Oct 18, 2006 06:36 AM
Firestarter1984
Dec 10, 2003 03:06 AM
