Do a8 / a6 wheels fit on an a4?
Old Jan 10, 2011 | 07:22 AM
normal's Avatar
Default Do a8 / a6 wheels fit on an a4?
Hi,
I'm looking to buy a used set of wheels and I seem to be finding more A8 and A6 wheels for sale (vs a4).
Can anyone tell me if they would be compatible on an a4?
In case year/models differ, I have a 1998 A4 3.2Q.
Thanks in advance for your help!
Old Jan 10, 2011 | 08:04 AM
chocalotstarfish's Avatar
Super Moderator
They will. They both are 5x112... Unless the guy says they are off of an A6 and they are really off a TT and then the guy shuts off his phone and leaves u screwed with useless $600 wheels...
Old Jan 10, 2011 | 08:33 AM
normal's Avatar
thanks for that tip.
Any suggestions on avoiding that situation (other than jacking up car and "trying one on")?
Should I be able to find any marking on wheel somewhere?
THanks
Old Jan 10, 2011 | 08:54 AM
CCA4's Avatar
anything with the 5x112 bolt pattern will fit.
Old Jan 10, 2011 | 09:02 AM
Super Moderator
Most wheels will tell you offset and size but not usually bolt pattern.
Old Jan 10, 2011 | 12:16 PM
turbo kraut's Avatar
Tech Guru
but you might need spacers to make them fit properly
Old Jan 10, 2011 | 02:43 PM
Tourbo24's Avatar
are you sure thats its a 3.2?
Old Jan 10, 2011 | 02:49 PM
Super Moderator
^^^ Didn't even catch that! It's not relevant to the question but still odd!
Old Jan 10, 2011 | 02:56 PM
Tech Guru
same here.... i just poked in to see responses....
Old Jan 10, 2011 | 03:01 PM
CCA4's Avatar
Thats a good point. Whats the offset on OEM A4 wheels, et35 or some such? Was the offset of the "sport" wheels different than the non-sport?
