Do you know what the difference is between a 2001.5 AWM and a 2002 AWM?
Old Feb 17, 2017 | 10:32 PM
A4TurboGuy's Avatar
Question Do you know what the difference is between a 2001.5 AWM and a 2002 AWM?
Hi guys,
Does anyone know what the difference is between a 2001.5 AWM and a 2002 AWM?
I didn't think there would be any difference, but I'm having my 2001.5 AWM replaced with a 2002 AWM (it came out of an '02), but the oil pan is different (it doesn't have the sensor in the bottom), the plugs from my engine are too big for the new engine and probably a few more things I haven't noticed yet.
Any idea why they would be different?
Thanks
Old Feb 18, 2017 | 02:56 PM
A4TurboGuy's Avatar
Bump.......
Old Mar 16, 2017 | 11:58 AM
nynoah's Avatar
What you are describing is the difference between an audi and a passat AWM. I would pull the pan off your car and run with your electronics.
Old Mar 17, 2017 | 12:30 PM
A4TurboGuy's Avatar
Hmmm. I never thought of that. Thanks.
I did notice that the oil pan is different (I swapped mine). Other than that, is there anything I should know (power differences, ECM issues, etc.)?
Thanks again.
Old May 24, 2018 | 01:11 PM
mobildetroit's Avatar
If you don't run the oil pan sensor your dash will be flashing the oil light at you I believe. it's also an oil temp sensor and drives the oil temp gauge if I'm not mistaken.
Also, the suspension that rests under the pan may be a bit different between cars, just guessing.
sollyd25
Dec 8, 2010 07:58 AM
octechgeek
Oct 27, 2008 11:27 PM
uruk
Jan 25, 2008 03:35 PM
cgbr4d
Mar 23, 2007 11:39 PM
