Does anyone else have this weird problem?
Old Feb 7, 2008 | 07:03 PM
AudiSensation's Avatar
Default Does anyone else have this weird problem?
My A4's trunk is f*%#ed!!
Every time I open it is nearly impossible to get it closed again- like the trunk won't latch and I have to try to shut it like 10 times before it latches.
Is this a common problem? Do I need to replace the latch or something? IT's really annoying!
Old Feb 7, 2008 | 07:24 PM
coleA4's Avatar
Default RE: Does anyone else have this weird problem?
i wouldnt say wierd. what is wierd is today i replaced an o2 sensor and when i reconnected everything and turned my car on i hit the window button and my sunroof started opening lol
Old Feb 8, 2008 | 06:30 PM
TorsenTaxi's Avatar
What year? Trunk lock has evolved a bit over the years. B7's seem to collect more snow and ice which effects opening. But neither my B5 or B7 has ever had latching issues.
Old Feb 8, 2008 | 06:45 PM
TDRILL's Avatar
Never actually seen a post complaining about the trunk latch so I don't think its a common problem. Sounds like the latch just isn't working right, assuming that the hinge mechanism etc isn't getting pinched / stopped so that the trunk isn't closing all the way / far enough to latch. Could be as easy as oiling it up, but likely you will end up just replacing the latching mechanism I would guess.
Old Feb 8, 2008 | 06:49 PM
M¥§T's Avatar
You could always start off by just spraying it with some WD-40 and see if that helps it any. If it does but doesnt last long, you may need to use some heavier oil or even replace it.
jonbonesjones
Mar 21, 2013 11:19 AM
Nicka430v
Apr 7, 2009 07:02 AM
MiniSpdRcr
Jun 1, 2008 07:51 AM
acamillo
Nov 13, 2007 11:44 PM
Mehurrman
Jun 8, 2004 02:21 PM
