drilled rear rotor question, HELP
Old May 13, 2008 | 04:15 PM
dr_zoidberg's Avatar
Default drilled rear rotor question, HELP
So I ordered some brake stuff from purems yesterday. Changing my mind at the last second and ordering drilled rear rotors instead of normal ones.
Just kinda realized that the drilled ones look like they are either for a left or right specifically. I called purems and asked if I needed a left and a right or if they were the same, the guy said they were the same, but I am not convinced.
Do I need left and right specifically for this, since the drill pattern goes in a spiral?
http://www.purems.com/products/product.php/II=890
I need an answer ASAP so I can call and change this before they ship it
Old May 13, 2008 | 05:45 PM
feerocknok's Avatar
Default RE: drilled rear rotor question, HELP
They just look different, but it's how it's supposed to be. Same with Porsche wheels and other things; they look different on one side than the other, but they figure that you can only see one side at a time.
Old May 13, 2008 | 06:26 PM
so drill pattern doesn't matter then? It's only slot position that matters? Since I only got drilled and not slotted I am okay then just ordering two of the same
Old May 13, 2008 | 08:54 PM
crsf29's Avatar
You are ok. The pattern of the drill holes makes no difference.
ccotton
Mar 12, 2012 11:30 AM
altonachrome
Nov 11, 2009 11:06 AM
twenty8red
Jun 4, 2009 10:33 AM
kchao2000
May 17, 2007 11:42 AM
elwolfe
Aug 29, 2005 07:16 PM
