Dumb, quick question...
Old Mar 28, 2012 | 03:51 PM
alexmurphy's Avatar
Default Dumb, quick question...
What is this? I just thought they maybe covered electrical parts or maybe was something for towing, but my friend has an 04 A6 and the bumps on his car pop up and spray his headlights. But they don't on mine...do they have a purpose?
Old Mar 28, 2012 | 04:04 PM
CCA4's Avatar
They're supposed to be headlight washers. If yours don't work that prolly means the pump is burned out, pretty common problem.
Old Mar 28, 2012 | 04:22 PM
vgo's Avatar
vgo
You need your headlights on and pull the wiper lever towards you for 3 seconds to make magic.
Old Mar 28, 2012 | 06:11 PM
M5S5's Avatar
Tech Certified
Fluid pressure overcomes spring tension when the squirters are applied , the little covers raise & squirt.
Old Mar 28, 2012 | 10:15 PM
alexmurphy's Avatar
Well I did not know that. They don't work on my car, I just tested it. How much money would this typically cost to fix?
Old Mar 29, 2012 | 12:42 AM
Skythe's Avatar
Most owners consider it a blessing that they don't work cause it could get messy
Old Mar 29, 2012 | 12:43 AM
MetalMan's Avatar
Any reason why you'd want to fix it? If they've never worked then you're not missing much IMO. Mine never worked either so I removed them. The space taken up by their fluid reservoir is much more useful than the headlight washers themselves (especially on the 1.8T, makes removing the oil filter a million times easier. Not to mention that's where my catch can now is).
Old Mar 29, 2012 | 04:29 AM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
They also only work when the headlights are on IIRC, so try that.
Old Mar 29, 2012 | 09:10 AM
CCA4's Avatar
The pump isn't too bad, less than $100 I think.
This.
amp832
Oct 22, 2009 10:54 AM
jojoampt
Jun 22, 2007 01:03 AM
AUDI12345
Oct 20, 2005 10:15 PM
lidonnit
Jul 4, 2005 12:28 AM
