DV relocation???
Hi there, I am a new member and have found this forum very useful. Just have 2 questions if anyone could help would be great.
1, my car has excessive lag of the line for a stock B5. I asume its the DV and would be replacing it soon, would you agree?
2, I have searched and did not see anyone swapping the DV around with the valve on top of it. My theory in doing so would give more room to use other DV's and room to adjust if need be. Has anyone tried this and could you see if there is going to be a problem?
Cheers
Cheers
I figured while I replace the DV I may as well replace it in the top position for easy future access, but were not sure what problems may arrise. And not sure if the valves are interchangable. Are the tubular sizes the same on both the valves?
I am thinking you think that a DV is the same as a BOV by your statement about adjusting it. A DV is NOT a BOV. You can't adjust a DV (unless you are just putting different springs it it depending on what valve it is).
Josh
Josh
After replacing the DV the first time you know what your doing. I can take mine out, grease it, change the spring, and have it back in under 5 minutes. Considering all the time it would take to relocate it and how it would probably make things worse I wouldn't worry about it
yeh, I wouldn't even try to move it. It would be senseless. When I removed the DV setup in mine I moved the BOV to the intake side of the car though. So if you decide to remove the DV setup entirely, you might want to consider that. I tell you what, full boost, thenswitching gears is much smoother when a BOV is on the intake manifold side of the car.
ORIGINAL: pimphell
