Ecu is sketchy
Old Jul 22, 2010 | 02:42 PM
HulkB5's Avatar
Only when boosting.
Old Jul 22, 2010 | 02:47 PM
onepoint8tee's Avatar
Did you ask the seller if it was chipped? I mean you would definitely know it if it was chipped by driving it if everything else was ok on your car, but not if you have a boost leak. A stock 1.8t is slow to begin with so it might had been very hard to notice if you had a leak before. If this ecu is chipped it might be boosting harder/louder, but leaking somplace before it gets to the manifold and causing you to have these symptoms. Idk just wild guessing. You are way less likely to get a boost leak fault when you have one with AEB engines.
Old Jul 22, 2010 | 02:50 PM
HulkB5's Avatar
Well i have a AEB engine, i don't have a boost guage so im gonna try and find a diy on how to check if i do have a boost leak.
Old Jul 22, 2010 | 02:54 PM
HulkB5's Avatar
It doesn't seem chipped.
From my impression chips seem to kick in at low rpms but this one the boost kicks in if i floor it just makes noise and hardly increases the power if it doesn't decrease it.
Old Jul 22, 2010 | 03:01 PM
When is the last time this car was driven before you noticed the louder turbo? And what's the story on why you are swapping ecus?
Old Jul 22, 2010 | 03:14 PM
HulkB5's Avatar
Yesterday, at 8:53 it was runnig fine.
swapped the ecus drove it at 9:15 and the turbo spooled louder.
I bought this one as a backup to use for when i shipped my ecu to get chipped.
I was just testing it last night.
Old Jul 22, 2010 | 03:19 PM
I'd check for a boost leak, definitely. If this ecu is chipped and caused a boost leak or a boost leak you had before to get worse then you might not need to send that other ecu out to get chipped! If the ecu had a engine faults when you put it in for the first time then it may have been running in limp mode (0-4 lbs of boost, scaled down fuel/timing.)
Old Jul 22, 2010 | 03:45 PM
  #18
HulkB5's Avatar
Oh ok!.
If it is running on limp mode?
How does it come out of that mode?
Old Jul 22, 2010 | 03:52 PM
  #19
HulkB5's Avatar
I think it may be limp mode.
Cause it feels almost as if its misfiring when i punch it.
Turbo sounds pretty normal.
Old Jul 22, 2010 | 03:59 PM
  #20
Disconnect the battery overnight and when you plug it back in, turn the ignition to ON and leave it there for a minute. Then start. See what happens. You'd more than likely have a cel w/limp mode.
