elim gt2871r/rods/boost
Old Apr 2, 2008 | 08:12 PM
driftking8732's Avatar
Default elim gt2871r/rods/boost
i was reading the bt treads and i have a question, i know i need to redue my rods above 31-330 tq bt until i can get enough money together to do that what is safe boost lv to run until then. also when i do the rods what else should i do since the motor is apart?
Old Apr 2, 2008 | 08:18 PM
cincyTT's Avatar
I'm make believe
Default RE: elim gt2871r/rods/boost
if you have or plan on running a 2871 elim, you dont really need rods. It just doesnt spool fast enough or make the same kind of tq
Old Apr 4, 2008 | 08:19 AM
400HPA4's Avatar
Contrary to popular belief, it is not just the torque that kills the rods, I have files that make well in excess of 500 puonds of torque and have been running stock internals (GT28RS-71R Eliminator big turbo) since 2004.
Pre-ignition (detonation) is what kills the rods...
Old Apr 4, 2008 | 02:57 PM
cincyTT's Avatar
I'm make believe
since when do elims, or ANY gt28 turbo make anything over 400ftlbs? A bad tune is a given btw. There is no way a stock 1.8t rod is going to hold that power for more than a dyno run or 2. You might want to stop filling peoples head with this kind of info and prevent them from blowing holes in there block.
Old Apr 5, 2008 | 01:24 PM
Monk's Avatar
ORIGINAL: 400HPA4
If someone has already gone through the trouble & expense of attaining a 500 ft.lbs. TQ level, it really does not make sense to skip the rods (unless they are forged in the first place). Even on a spot-on tune, it is way too risky.
Old Apr 5, 2008 | 04:41 PM
01afour's Avatar
yeah when i put my gt28 in all im changing is rods. i was told anything over 300hp or 300lb/ft shoud replace the rods. you dont need to do that much more to it until you go BAT. taking apart the top end is not as big of a job as a whole motor build. if your doing a whole motor build theres a lot more you can change...and it would be a bit of a waist of money to rebuild the motor for a gt28. hope that helps a little.
Old Apr 5, 2008 | 05:08 PM
cincyTT's Avatar
I'm make believe
The only gt28 series turbo that needs rods is the 2871r. The rest will be fine with a good tune and boost control. You can even run a 2871r with pump gas and stock engine also. Its when you start maxing out the turbo when you need the rods.
Old Apr 6, 2008 | 02:37 PM
01afour's Avatar
im puttin in a 2871r and new rods. but if i set up a program to run on cam2 race gas should i change more internals then that??
Old Apr 6, 2008 | 04:13 PM
cincyTT's Avatar
I'm make believe
the rods are the only thing that will break. The rest of the stock parts have seen over 700bhp
chris120391
Apr 3, 2011 11:32 PM
chris120391
Feb 19, 2011 08:06 PM
chris120391
Dec 11, 2010 04:56 PM
tooxtreme8813
Sep 6, 2009 02:11 PM
MasterV
Jun 2, 2008 12:37 AM
