Empty Cruise Control Fuse Slot
Old Jun 29, 2008 | 11:41 AM
seabassx's Avatar
Member
Default Empty Cruise Control Fuse Slot
I have an automatic 98.5 2.8Q A4 that I've owned for almost three years. The cruise control used to work perfectly, but now seems to be dead. I looked through my fuse box and slot #11 (which the manual associates with cruise control for automatic transmissions) is empty - it does not have the little clips that should hold a fuse in. At some point I was working on some other problem and removed, inspected, and replaced all of the fuses one at a time. Is it possible that I pushed the clips out of the other end of the fuse box perhaps?
I did a search and it seems some other people have noticed the same thing, but I was not able to see if there was ever a conclusive resolution (presumably some of them may also have had manual transmissions.) It would be really helpful if someone with a similar car could look at their fuse box and let me know if you have anything in slot 11.
Old Jun 29, 2008 | 05:20 PM
sineo's Avatar
Default RE: Empty Cruise Control Fuse Slot
No, I don't. And neither does the other person with a nearly identical thread on the same page. Check fuses 5 and 13 and if those are fine, it'll be time to look into other possibilities.
Jmana
Dec 9, 2009 10:06 PM
chooch628
Sep 5, 2007 03:32 AM
der_reisende83
Aug 1, 2007 10:32 AM
liv2wrshp
Mar 22, 2007 04:49 AM
kbuff97A4
Sep 27, 2006 03:10 PM
