Cruise Control Out...Fuse?
Old Jul 6, 2007 | 11:47 AM
der_reisende83's Avatar
Default Cruise Control Out...Fuse?
I just recently purchased a 1997 A4 2.8 Quattro, Automatic from an individual. I am loving it, but the cruise control does not work on it. I have been told that, obviously, the easiest fix for it could be replacing the fuse if it is bad. I opened the fuse box yesterday, though, and there is a guide telling the fuse number locations but not what each fuse is for. Does anyone know the fuse number and size for the cruise control on a 97 A4 2.8 Quattro automatic? Thanks!
Old Jul 6, 2007 | 03:23 PM
akielb's Avatar
Default RE: Cruise Control Out...Fuse?
Its in the owners manual - don't have mine handy right now, just check there. Another posibility, and how it was in my car when the cruise didn't work, the cruise stalk is bad
Old Jul 6, 2007 | 08:19 PM
JettaRedII's Avatar
Most likely the switch is bad and needs replacing. On the www.audiworld.com tech site, there is listed a "repair" process that involves cleaning the contacts, but it never worked for me.
Old Jul 6, 2007 | 08:37 PM
theguy1084's Avatar
Brake light switch could be the cause. I have see that. Scan for codes. I have also seen that sometimes for some odd reason the module will lose its coding for the cruise and not even know that it has that option. Fuse # by the way is S13. I would check the fuse and then look into a brake light swtch. It is in series with s13 and if it isnt good than the cruise stalk isnt going to get power.
Old Jul 6, 2007 | 09:02 PM
whytap109's Avatar
ya mine stopped working in the middle of a road trip could that be an issue with the fuse cause it was working perfect then boom it just quit working
Old Aug 1, 2007 | 12:49 AM
fritz's Avatar
has anything come of this, mine finally went out as well. i did notice that it worked a while, then when i hit a slight incline, it turned off and i couldnt turn it back on. i have a 1997 1.8T qm
Old Aug 1, 2007 | 01:11 AM
sineo's Avatar
I have a non-functioning cruise control, too. Luckily, I just bought the car and the dealership will make it right. They "fixed" it today, it worked this afternoon, then nothing tonight. They replaced the module, so apparently the stalk is bad. I looked through all of the old complaints about cruise control and I didn't ever see any resolution, so I will let you know when they figure out what the actual problem is.
Edit: Okay, I lied, the cruise control does work now...I thought it didn't, but it was user error. So, anyway, what they did to fix it was replace the module. I think it was like $150 for the part and who knows what they paid for labor, but that gives you an idea.
Old Aug 1, 2007 | 10:32 AM
grim2.8's Avatar
i have seen the boards on several A4's that have burned out the chip that controls the cruise but hopefully its not that but you may wanna check it to be sure
Jmana
Dec 9, 2009 10:06 PM
seabassx
Jun 29, 2008 05:20 PM
chooch628
Sep 5, 2007 03:32 AM
liv2wrshp
Mar 22, 2007 04:49 AM
kbuff97A4
Sep 27, 2006 03:10 PM
