engine codes!!
Old Apr 29, 2008 | 11:45 AM
chaos92287's Avatar
Default RE: engine codes!!
might be. if your changing the turbo i would do that first, clear the codes, and see if the code comes back. if it does, you need a new cat
Old Apr 29, 2008 | 03:25 PM
SuprA4's Avatar
(dont mean to thread jack)
BUT! since where on the topic of PO422- Main Catalyst Below threshold Bank#1....im going to do the non fouler "mod" do i have to do both (2nd 02 sensor is soo hard to do in your garage) or can i get away with just doing the 1st 02 sensor??? or should i just do the 2nd??
Old Apr 29, 2008 | 04:36 PM
Lefty's Avatar
what is the non fouler "mod"?
Old Apr 29, 2008 | 04:59 PM
chaos92287's Avatar
p0422 is not your o2 sensor. it means your o2 sensor is sensing the cat is going bad. and you don't wana touch the first o2 sensor since its reading the air coming right out of the engine, the second o2 sensor, the one you do the non fouler mod to, reads the air after its passed through the cat. and its not that hard to reach
lefty- its essentially just a spacer to put your o2 out of the main stream of air, therefore it tricks the sensor into thinking nothing is wrong. people with test pipes use it to get rid of the constant CEL
SuprA4's Avatar
https://www.audiforums.com/m_206746/tm.htm
it tricks the 02 sensor into reading less (stuff) so it wont throw a code...and in reading that post i answered my own question only put it on the 2nd 02 sensor
This could work in your case but sounds like your cat is on its last life...its worth a try for 4 bucks
Old Apr 29, 2008 | 05:08 PM
SuprA4's Avatar
p0422 is not your o2 sensor. it means your o2 sensor is sensing the cat is going bad. so the non-fouler mod won't help you out
not necessarily i have a new cat in my car and thats the code im throwing...also i have a high flow cat and he has a stock cat so in his case, his cat is most likely done
Also is there a possiblity that our cats could be "clogged" or blocked off by something??
Old Apr 29, 2008 | 05:21 PM
chaos92287's Avatar
where did you get the high flow cat at?
this is straight from auditech's mouth
It means exactly what it says, the O2 sensors are measuring insufficient functionality of the cat converter. When you get that code there is only 1 repair, replace the cat converter.
when the o2 sensors go bad they set off a different code
Old Apr 29, 2008 | 07:13 PM
  #18
Lefty's Avatar
Well ****! How much does a new cat cost on one of these? Damn costs of a free car!![:@] Oh, and I'm located in Cali. I'm assuming it wont be cheap.
Old Apr 29, 2008 | 07:28 PM
  #19
chaos92287's Avatar
its not that expensive unless you buy a new one. i would pick one up off a car being parted out
Old Apr 29, 2008 | 10:11 PM
  #20
SuprA4's Avatar
i got a labree high flow cat! no way it can be bad and i replaced tha rear 02 sensor when i put it in
