engine codes!!
(dont mean to thread jack)
BUT! since where on the topic of PO422- Main Catalyst Below threshold Bank#1....im going to do the non fouler "mod" do i have to do both (2nd 02 sensor is soo hard to do in your garage) or can i get away with just doing the 1st 02 sensor??? or should i just do the 2nd??
p0422 is not your o2 sensor. it means your o2 sensor is sensing the cat is going bad. and you don't wana touch the first o2 sensor since its reading the air coming right out of the engine, the second o2 sensor, the one you do the non fouler mod to, reads the air after its passed through the cat. and its not that hard to reach
lefty- its essentially just a spacer to put your o2 out of the main stream of air, therefore it tricks the sensor into thinking nothing is wrong. people with test pipes use it to get rid of the constant CEL
https://www.audiforums.com/m_206746/tm.htm
it tricks the 02 sensor into reading less (stuff
) so it wont throw a code...and in reading that post i answered my own question only put it on the 2nd 02 sensor
This could work in your case but sounds like your cat is on its last life...its worth a try for 4 bucks
) so it wont throw a code...and in reading that post i answered my own question only put it on the 2nd 02 sensor This could work in your case but sounds like your cat is on its last life...its worth a try for 4 bucks
p0422 is not your o2 sensor. it means your o2 sensor is sensing the cat is going bad. so the non-fouler mod won't help you out
Also is there a possiblity that our cats could be "clogged" or blocked off by something??
where did you get the high flow cat at?
this is straight from auditech's mouth
when the o2 sensors go bad they set off a different code
It means exactly what it says, the O2 sensors are measuring insufficient functionality of the cat converter. When you get that code there is only 1 repair, replace the cat converter.
