Engine died and wont start
To start I just want to say hi! I am new to this site, but not new to forums. I have been searching for a while now to try to find out the reason for this problem and have a few ideas. I was driving home today and and my car just died. no sputtering or any warning it just stopped running, and i have not been able to start it since. My car is a 1997 a4 2.8 quatro Tomorow i am planning on scanning the computer for any codes that might have popped up. I am thinking it has something to do with a clogged fuel filter or something with fuel. if anyone has any information that could help that would be great.
Spark, fuel, timing.
Could be as simple as a bad battery connection if you have no power and car doesn't crank. If the engine cranks, it could be fuse to fuel pump. Could be ECU.
Saving the worst scenario for last, it could be your timing belt has snapped, which given your story fits
. Assuming that you have power to the car and the fuse to the fuel pump isn't gone, I'd have someone check the timing belt ASAP and not crank the car. If the belt is snapped, turning the engine over can damage the valves further, if they already aren't toast.
The car does turn over, and i did check the timing belt and it has not snapped. I also checked the fuse to the fuel pump and its ok. Thanks for all of the help so far. I am going tol check the spark plugs today, and change the fuel filter, hoapfully its an easy fix.
someone correct me if im wrong but if the car doesnt turn over then it would be the battery but seince it died while he was driving couldnt it be the alturnator *sp*
What exactly do you mean by it does not turn over? Like do you turn the key and nothing? Does the radio/accessories come on when you turn the key? I agree that if this is the case, I would start with jumping it and see if it's the battery.
