Engine light just turned on
Old Sep 3, 2016 | 10:50 PM
Audikari's Avatar
Default Engine light just turned on
Received a code p1136 in my 98 Audi A4
Could this hose be the problem?it's sucked flat
Anyone tell what this hose it's called please
Thanks
Attached Thumbnails Engine light just turned on-photo868.jpg   Engine light just turned on-photo193.jpg   Engine light just turned on-photo289.jpg
Old Sep 4, 2016 | 10:48 AM
A4TurboGuy's Avatar
That's a vacuum hose. You need to find out where your vacuum issue is.
17544/P1136/004406 - Fuel Trim: Bank 1 (Add): System too Lean
Possible Solutions
Check Mass Air Flow (MAF) Sensor
Check Fuel Pressure Regulator
Check Fuel Pump
Check Intake/Exhaust System for Leaks
Check Secondary Air Injection for Leaks
Check Vacuum Lines for Leaks
Special Notes
Fuel Trim Info
When this fault is stored and external vacuum leaks are not found, less obvious problems may be present:
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Check Brake Booster and Hoses
Check Electric Vacuum Pump ( If Applicable )
Check Crankcase Ventilation System for faulty components. When the PCV or Crankcase Ventilation System is faulty, vacuum is typically present under the oil cap and misfire faults are common.
Old Sep 4, 2016 | 11:36 AM
Audikari's Avatar
Thanks
Old Sep 5, 2016 | 07:32 AM
A4TurboGuy's Avatar
My Pleasure.
audia6s
Apr 9, 2008 05:11 PM
skylinergtr
Mar 24, 2008 12:02 PM
EpicA4 1.8T
Apr 26, 2007 02:36 PM
deviouswraith
Oct 12, 2006 03:40 AM
