Engine mounts on Audi A4 2.6 - B5
Old Apr 14, 2015 | 06:24 PM
HarryAudi2010's Avatar
Default Engine mounts on Audi A4 2.6 - B5
How do I change all engine mounts on my 1997 Audi A4 2.6
Old Apr 14, 2015 | 09:32 PM
elduderino200's Avatar
Put the car on jack stands or ramps.
Put a jack stand (or better yet - 2) under the oil pan. Best to put a 2x4 across first.
Drop the sway bar.
Take down the bracket.
Take down the mount (you'll need a shorty wrench to get up in there and get the top bolt).
Reverse to re-assemble.
There's a million videos. This was probably the best for me.
Old Apr 15, 2015 | 02:27 PM
turbo510's Avatar
The top nut on mount nearest the air box is MUCH easier to reach with the air box removed, which should only take a few minutes once you've done it a time or two. Even just removing the air cleaner so the ratchet handle can extend into the air box may be enough to make the job much easier. Use a 13mm U-joint socket here. Remember to let the engine idle with the mount nuts loose before final tightening.
Cookryan83
Jul 3, 2013 04:40 PM
minexxx
Sep 6, 2012 05:08 AM
QuattroGuy2003_1.8T
May 19, 2011 02:13 PM
KinkySlayer
Sep 2, 2010 02:22 AM
