Engine Speed sensor and Brake Light Switch fault
Old Oct 15, 2010 | 12:09 AM
ady_m's Avatar
Default Engine Speed sensor and Brake Light Switch fault
Hi everyone.
I have an Audi A4 '97 model 2.6L ABC.
There is an intermittent fault that is gradually getting worse and worse.
From cold (most of the time) it behaves normally, until....
The dash lights up like a christmas tree.. pretty much all the warning lights come on including the ABS light and every gear light (auto box). I lose the signal to the tacho. 5 beeps follow closely!!
I have had the car on a VAG-COM and the only faults it shows are Engine Speed Sensor and Brake Light Switch.
To add to the mystery and before I start throwing cash at it (which is in demand everywhere else at the moment!!).. from time to time it is so intermittent that you can actually see the tacho failing, then coming back to life, before it hits 0 revs!! BUT... when I touch the brake it kills it totally... then release the brake and it comes back again, albeit very erratically.
I have been told by one Audi mechanic to change the brake light switch as it has 4 wires.. 2 for the lights and 2 for the ABS.. BUT.. mine only has 2 wires.. black/red and yellow/red.. these appear also in the ABS control plug at the ABS unit.. do they go straight there and are the lights controlled by the ABS unit? I have also been told that the Tacho signal passes through the ABS unit also. I would like to think that the ABS unit hasnt filled its undies with cottage pie as they are really expensive here in NZ!...
It also occasionally comes good after some time and resets itself on the move and the warning lights go out. The Gbox lights then reset after slowing to a stop.
Any ideas anyone please?? your help on this is much appreciated...
Thanks
Ady
Old Oct 16, 2010 | 02:32 PM
ady_m's Avatar
Any idea`s anyone please? Bad earths etc?? Thanks
rossboard
Jun 2, 2021 09:32 AM
bobbyenglish61
Aug 27, 2013 07:55 AM
PennSt8_A4
Nov 28, 2012 09:47 PM
RK911
Jun 20, 2012 08:27 AM
