Engine and transmission mounts, purchase?
im not sure what a reasonable price is to you, but i have the 034motorsport street density mounts all around and they are a nice improvement. 034motorsport.com
edit:
http://www.audizine.com/forum/showthread.php?t=221697
if you PM that dude you can even get the audizine'r discount
edit:
There is movement in the stick shift when stopping and starting. Someone at one of the online stores said a "snub mount" would cure a lot of the movement in a manual shifter. Any ideas?
All 5 mounts, motor, snub and transmission offered for $177.75 plus shipping.
I may try the front "snub mount" for $29.95. Installation looks manageable.
good to see people use the search function.
a snub mount will help as the stock one is probably destroyed by now, if you still have your stock shifter you could upgrade to a JHM shifter and linkage, its a little expensive but its absolutely worth every penny.
http://www.jhmotorsports.com/
I just installed 034 street density engine and trans mounts. These things are waaaaaay stiffer than stock, but bearable for street use. I'm running the stock snub, Stern rear diff bushings, and a Stern Rear diff power ring (which makes a huge difference).
o0hmikee
Jun 18, 2013 02:01 PM
