Engine and transmission mounts, purchase?
Old Feb 5, 2009 | 04:05 AM
lorencew's Avatar
Question Engine and transmission mounts, purchase?
Where can I buy on-line, some reasonably priced engine and transmission mounts?
Old Feb 6, 2009 | 11:43 AM
brrman's Avatar
http://www.purems.com has what you need.
Old Feb 6, 2009 | 12:10 PM
ghost6303's Avatar
im not sure what a reasonable price is to you, but i have the 034motorsport street density mounts all around and they are a nice improvement. 034motorsport.com
edit:
http://www.audizine.com/forum/showthread.php?t=221697
if you PM that dude you can even get the audizine'r discount
Old Feb 6, 2009 | 05:58 PM
Tweaked's Avatar
www.DTHaus.com
They carry the 034 mounts.
Old Mar 28, 2009 | 08:59 AM
lorencew's Avatar
Default Movement in stick shift when stopping and starting.
There is movement in the stick shift when stopping and starting. Someone at one of the online stores said a "snub mount" would cure a lot of the movement in a manual shifter. Any ideas?
All 5 mounts, motor, snub and transmission offered for $177.75 plus shipping.
I may try the front "snub mount" for $29.95. Installation looks manageable.
Old Mar 28, 2009 | 03:31 PM
ghost6303's Avatar
good to see people use the search function.
a snub mount will help as the stock one is probably destroyed by now, if you still have your stock shifter you could upgrade to a JHM shifter and linkage, its a little expensive but its absolutely worth every penny.
http://www.jhmotorsports.com/
Old Mar 29, 2009 | 12:14 AM
Tweaked's Avatar
Personally, I feel a snub mounts just adds vibration and the movement isn't harnessed all that well. Understand that the snub connects the front of the engine to the front crossover pipe, which is bolted to the frame. The engine and trans don't tip back and forth that way nearly as much as they rock side to side. I'm sure everyone has an opinion, but personally, I can do without the excessive vibrations often caused by a stiff front snub for my street car.
I just installed 034 street density engine and trans mounts. These things are waaaaaay stiffer than stock, but bearable for street use. I'm running the stock snub, Stern rear diff bushings, and a Stern Rear diff power ring (which makes a huge difference).
stig.bjerke
Dec 19, 2013 08:39 AM
VeGaS
Nov 10, 2010 10:16 AM
S4FIRE
Jun 24, 2008 12:35 AM
Dj Spiel
Jun 2, 2008 04:31 PM
