error code p0411
Old Mar 17, 2011 | 08:13 PM
silverbullet00's Avatar
Default error code p0411
2000 a4 1.8t secondary air injector incorrect flow need to no what parts to change any help would be great thank you
Old Mar 18, 2011 | 03:45 AM
Cristisor's Avatar
This is what Ross-Tech says:
Possible Causes
* Fuel Pump Relay (J17) faulty
* Hoses/Pipes to/between Components faulty/clogged
* Secondary Air Injection Pump (V101) faulty
* Secondary Air Injection Pump Relay (J299) faulty
* Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions
* Check Fuel Pump Relay (J17)
* Check Hoses/Pipes to/between Components
o Check Secondary Air Injection Hoses/Pipes for Carbonization
* Check Secondary Air Injection Pump (V101)
* Check Secondary Air Injection Pump Relay (J299)
* Check Secondary Air Injection Solenoid Valve (N112)
Start by checking the vacuum lines, 4 for 1.8T engine, and if all the lines are ok then move on the what Ross-Tech says.
Old Mar 26, 2011 | 12:48 PM
Default possible solution
there ended up being a hole in the hose that goes from air pump to another hose or something waiting to see if CEL comes back on thanks for the help
Old Mar 26, 2011 | 03:29 PM
morpheous's Avatar
Post pictures of the hose that had a hole,please.
WhitefeatherTexas
May 17, 2011 10:23 PM
silverbullet00
Mar 12, 2011 08:15 PM
silverbullet00
Mar 12, 2011 07:26 PM
scottrod
Jan 22, 2011 02:46 AM
HuskyRips
Aug 9, 2010 10:25 AM
