the famous "clunking" noise
Old Aug 24, 2011 | 12:54 PM
supergoober752's Avatar
Default the famous "clunking" noise
Many have probably herd the famous ca clunk sound from either your front left or right wheels going over bumps. Well i had this on both sides and replaced all my control arms, upper lower and tie rods and its still there? any ideas.
Thanks
Old Aug 24, 2011 | 01:06 PM
CCA4's Avatar
I've experienced this on both of my A4's and in both cases it was the brakes. The friction material had separated from the metal backing and was clunking around whenever i wasn't on the brakes.
Old Aug 24, 2011 | 01:50 PM
That's weird I've never herd that before. How did you go about fixing it?
Thanks
Old Aug 24, 2011 | 03:03 PM
CCA4's Avatar
I did the A8/TT upgrade lol. But I'm sure just doing new pads/rotors and cleaning up the brake components would be fine.
Old Aug 24, 2011 | 03:24 PM
MetalMan's Avatar
If it's not brakes I wonder if it could be worn upper strut mounts?
Old Aug 24, 2011 | 03:34 PM
ImTheDevil's Avatar
Metalman, that's what I was thinking. It also can be CV joints starting to fail.
Old Aug 24, 2011 | 03:36 PM
CCA4's Avatar
Thats a good call!
Old Aug 24, 2011 | 04:01 PM
Dozanti's Avatar
This ! My MKIV jetta as well as my b5 a4 did this and I knew it was the cause, just never replaced them.
Old Aug 24, 2011 | 08:31 PM
MetalMan's Avatar
I've also got an odd clunk on the driver side in the front, coming from around the steering rack. Seems to me it's the inner tie rod, so that could be another possibility here.
I've tried replacing my upper strut mounts and had no luck getting the top nut off. Anyone have any tricks for this?
Old Aug 25, 2011 | 07:42 AM
Dozanti's Avatar
Break it loose with the weight of the car on it, with a strong impact gun
