Firewall/pedal mounts
Old Jul 2, 2010 | 05:46 PM
BrianJanice's Avatar
Default Firewall/pedal mounts
Hi, my '99.5 1.8TQM has a really low gas pedal. I just replaced the throttle cable under the impression that it had been stretched, but it did not fix the problem. I am wondering if this is normal to feel such a low pedal on the 99.5, or if maybe something is bent under there... I cannot even force it to get higher up manually without the cable attached.
Also, when I step on the clutch/brakes all the way, the brake booster moves a little bit under the hood as if something is loose, allowing stuff to move under there. I guess some of the older Audis had a problem from braking/clutching so much that it cracked the firewall and it had to obviously be repaired. I am wondering if this could be my issue...
B5 owners unite and tell me what could be wrong with my car!
Old Jul 3, 2010 | 03:39 PM
Any 99.5 owners who think their gas pedal is lowe than a different car? It's not much lower than the brake, but it touches the floor pretty easily.
aa2by2
Jun 11, 2012 01:17 PM
PzPicklez
Sep 6, 2010 10:57 AM
E~double~D23
Mar 17, 2009 07:04 PM
Proven
Sep 27, 2006 12:58 AM
