first audi and it needs help!!!!
Old Jan 7, 2013 | 09:41 PM
jfiscus86's Avatar
Ok will do and ill let you know
Old Jan 11, 2013 | 10:17 PM
jfiscus86's Avatar
Alright worked on the car alil tonight checked fuses all looked good opened up ecu box looked dry as can be.. Hooked up new central locking pump with the same code as the original one but the doors still dont unlock with the button in the car or make any form of noise.And I'm still in the same boat but I got all the inside lights working but now I have 1n 2 display under my odometer and now the radio says safe on it...so now I' guess the car is in anti safe mode?? Does the key need programmed?
Also another interesting fact I noticed is the 2 keys I have one is supposively the regular key and the other is a valet key? Should the regular key unlock the drivers door and the trunk? My ignition key will not open the door or the trunk. So also could that be a problem with the car not wanting to start?
Also one door being stuck locked have anything to do with it being in safe mode?
Old Jan 11, 2013 | 11:47 PM
jfiscus86's Avatar
alright messed with it more.....found out i need a code to get radio out of safe mode have the code not to worried about that....
got the one door to unlock just sucked on the red vacuum pump till i turned purple and heard all the doors pop and that door finially opened thank goodness...but def cant unlock the doors inside the car and the new locking pump i put in makes zero noise when i hit the lock button so my new question is should it make noise is there any certain things i can check on??
my other thing is still about the keys i found another set in the car that were made...one key works in ignition and nothing else and the other will unlock only the drivers door so my question is should the master key open the door and trunk? could that be a problem
now back to starting the car i turn the key everything works fuel pump is working there is a code under odometer that says 1n 2 on it....go to turn car over soon as i turn the key over the lights flicker off like when you start any car but there is no crank...so any suggestions would be lovely guys
also checked fuses all looked good didnt run a test light to check power tho
