Flashing CEL even after replacing Coil pack and plugs
Old Sep 23, 2008 | 05:57 PM
a224932's Avatar
Angry Flashing CEL even after replacing Coil pack and plugs
On my 99.5 Audi A4 1.8T Q I had a flashing cel and hooked it up to VAG and found out that cylinder #2 was misfiring. (16684 - Random/Multiple Cylinder Misfire Detected, P0300 - 35-00, 16686 Cylinder #2 Misfire - P0302 - 35-00)
I bought a new coil pack and a new set of NGK spark plugs. I cleared codes and swapped out coil pack for cylinder #2 and all spark plugs.
I started the car and noticed that the CEL was still flashing. So I took the coil pack from cylinder #3 and swap w/ cylinder #2 to check to see if the new coil pack was bad. Same error from vag, cylinder #2 misfiring. I checked the brand new plug in cylinder #2 and it looks like it is not firing as there is no residue.
Thought? I don't want to take it in, but am running out of options and want to get my car running. My only guess is that the plug wire for #2 cylinder is bad. Any other thoughts? The wires look a little complicated to swap out. Any write-ups on how to do it (even just to test if one of the wires is bad by swapping it out with another wire)?
Old Sep 23, 2008 | 06:28 PM
a224932's Avatar
Default Think I might have figured this out
I found a write-up on how to check the Power Output Stage module N122. I am going to do this as I suspect this could be the cause. Here is the link to the write-up that shows how to test this:
http://forums.audiworld.com/a4/msgs/1594531.phtml
If this is not the issue, then I will swap out the plug wires.
Hopes this helps someone else...
Old Sep 23, 2008 | 06:49 PM
onepoint8tee's Avatar
ICM (power output stage) is pretty much the last thing to replace to cure the misfire if you've done the plugs and coil packs.
Old Sep 23, 2008 | 08:44 PM
chaos92287's Avatar
did you gap the plug correctly?
Old Sep 23, 2008 | 10:23 PM
Prizmatik's Avatar
I am curious to here how this ends. Keep us updated. Good Luck
Old Sep 23, 2008 | 10:41 PM
Jc61990's Avatar
was about to ask same thing, make sure the gaps on the plugs are in the 0.028 - 0.035 range
Old Oct 4, 2008 | 04:33 AM
a224932's Avatar
Sorry for the delay in response. I just got the part today and installed it. Flashing CEL was gone (need to reset CEL with VAG) and all cylinders are firing (immediate difference).
The good news is I know a lot more about the ignition system on my Audi and it has new NGK spark plugs as well as a new coil pack which did not fix the problem, but needed to be replaced as they were getting old.
Car runs great!!!!
Old Oct 4, 2008 | 09:44 AM
CRAZYHAWK's Avatar
Does your car have an ignition control module?
Old Oct 4, 2008 | 03:07 PM
a224932's Avatar
Yep. Problem was the Power Output Stage module N122. Replacing that fixed the problem. Also I did check the gapping on the spark plugs. From what I remember NGK's come pre-gapped, but I checked them anyway.
Fusion
Apr 27, 2010 07:30 PM
Mr_GoodKat
Apr 8, 2010 01:15 PM
brandons34
Sep 11, 2007 11:22 AM
d_maniac
Jun 2, 2006 01:06 AM
Suite3.0A4
Aug 25, 2005 08:53 PM
