Flashing Red Light, nothing on Vag-Com
Old Jul 29, 2008 | 05:03 PM
megawhizz's Avatar
Default Flashing Red Light, nothing on Vag-Com
Hello people,
My 2001 A4 2.8 recently started displaying a flashing red Engine Coolant symbol. This displays shortly after starting, but if I keep driving the engine or oil temp itself (from the analog dials on the dash) does not rise. Car performs well with no symptoms. The red symbol continues to display.
I ran a vag-com diagnostic and got no fault codes. Coolant level itself appears to be okay. Can anyone help with further debugging?
This is my first post, look forward to making many more!
MW
Old Jul 29, 2008 | 05:17 PM
Audi_Skydiver's Avatar
Default RE: Flashing Red Light, nothing on Vag-Com
Make sure the coolant level sending sensor thingy is plugged all the way in on the bottom of the tank. Also start the car up and let it warm up THEN check the coolant to see if it's ok still.
Also are you saying your oil temp and coolant temp gauges both read 0 when your car is warmed up? If so you might have a nice electrical problem or ALL three of those sensors went out. Did this all start happening at the same time?
Josh
Old Jul 29, 2008 | 05:22 PM
megawhizz's Avatar
Thanks for the quick reply.
* You say the sensor is at the bottom of the tank? I will check.
* Checked car when it was warm, level still ok
* Oil temp reads between 150 and 250, and coolant temp is midway between cold and hot. Sorry if I wasn't clear earlier
Old Jul 29, 2008 | 07:04 PM
Oh, ok the the other (coolant and oil) temps are fine.
Thats right where they should be.
Check the coolant level sensor though. It might be coming unplugged or it's bad and you will need a new one.
Josh
zzr
Nov 9, 2009 05:55 AM
blanthony
Mar 25, 2006 01:18 PM
