Fluctuating temp gauge??
Old Sep 23, 2010 | 07:14 PM
a4nick's Avatar
Default Fluctuating temp gauge??
So i just did my timing belt and water pump now, when im driving it runs right in the middle but when i am idling or put it in neutral to coast down a hill the temp gauge will drop pegged to cold. what could this be? the heater inside the car stays warm the entire time.
Old Sep 23, 2010 | 10:01 PM
a4nick's Avatar
Alright update, I was cruising in 5th gear and all the sudden it dropped to cold, down shifted into 4th and it went back up. Im leaning towards coolant temp sensor, is there anyway i can test it?
Old Sep 24, 2010 | 12:37 PM
MetalMan's Avatar
Did you also change your thermostat when you did the timing belt and water pump? It might be unrelated but is worth asking.
Old Sep 24, 2010 | 01:27 PM
a4nick's Avatar
I didn't change it but, when the tstat is closed the car will overheat correct? and if its stuck open the car wont heat up while driving. The car heats up while driving but then when i stop and idle the temp will drop.
Old Sep 24, 2010 | 02:19 PM
MiamiA4guy's Avatar
It sound's like that gauge is either losing power or losing signal you might want to check if everything down there is connected correctly and no lose wires down there because what ever is causing the problem is only happening when the engine is not working hard enough like when your cruising and idling.
Old Sep 24, 2010 | 04:43 PM
a4nick's Avatar
yah almost like the sensor is not reading correctly when the coolant isn't flowing as much? idk its quite tricky ill take a look at the wiring connection and make sure everything is solid there.
Old Sep 28, 2010 | 10:06 PM
markymarc's Avatar
99% sure it's your tstat....that happened to me....how's your heat working? that will really tell you....
Old Sep 28, 2010 | 10:09 PM
a4nick's Avatar
I dont think its the tstat my heat is perfect, and it never over heats which are the symptoms of a closed tstat but it heats up which is the opposite symptom of a open tstat i think its just the sensor
zedea
Jan 18, 2013 03:11 PM
rradovitch
Feb 19, 2010 03:52 PM
jchaffee1
Nov 18, 2009 11:41 AM
Russell2686
Jul 8, 2009 11:55 AM
white95coupe
Dec 23, 2007 08:40 AM
