Flushing Heater Core...again
Old Sep 13, 2012 | 11:26 AM
mtroxel's Avatar
Still scares me. The top of the core and the tubes that go through the firewall are plastic. Might be OK....I'd want to talk to someone else who had done it.
Old Sep 14, 2012 | 10:37 AM
lone_star_dsl's Avatar
I'm scared of it as well. I just use extremely hot water.
Old Sep 14, 2012 | 02:40 PM
ECS Tuning's Avatar
Sponsor
If after several flushes your heat is still intermittent its probably time to replace the core.
The part its self is rather inexpensive if you got with aftermarket but the removal/install is where people gripe. It's not complicated, rather just tedious.
We have heater cores below.
Click HERE to order or for more information.
Let me know if you have any questions.
Jason
Old Sep 14, 2012 | 09:07 PM
I'm gonna flush it again as a temporary measure then I'm gonna flush the coolant system in the hopes that it is fixed permanently.
It's gonna take an act of god for me to drop $2,000 to fix the heater core in a $5k car.
Old Sep 14, 2012 | 09:11 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Just do it yourself! It's as easy as an oil change! Shouldn't take more than 30 minutes.
Audi area: Audi A4 (B5). Heater Core Swap
Old Sep 14, 2012 | 09:15 PM
mtroxel's Avatar
I have the feeling a new heater core would be clogged about as fast as the one you have now. You have too much junk floating around in your cooling system. That's what you have to attack.
Old Sep 15, 2012 | 07:19 AM
jonbonesjones's Avatar
Moderator
exactly like mtroxel said, if you don't solve the actual problem here, the problem being coolant, your just going to be replacing it again in the future along with the rest of the cooling system,.
Old Jan 19, 2014 | 08:33 PM
  #18
Figured I would update this post:
On that third flush, I used CLR and near boiling water. Managed to get a lot more crud out than before. I took it to Jiffy Lube and had them do a full flush on it. Since September of 2012, it has worked flawlessly.
Old Jan 20, 2014 | 09:44 AM
  #19
mtroxel's Avatar
You said you saw peanut butter looking stuff come out didn't you? Had to be stop-leak. Now that Blomberg is out of office in NY, he should move from 64 ounce soda to stop-leak. That stuff should be banned!
Old Jan 20, 2014 | 11:48 AM
  #20
Could have been but there's no leak at the moment.
Triniboy
Mar 5, 2015 01:40 PM
mtroxel
Aug 11, 2014 07:25 PM
DiscoJaker
Nov 16, 2008 09:44 PM
DiscoJaker
Nov 3, 2008 12:37 PM
