Flywheel decision help
So I finally tore out my tranny today on my 1.8t quattro. With an exhaust, intake, k04, fmic, chipped, stage 2 clutch, forge d/v. Should I be fine resurfacing my flywheel or do I need a single mass flywheel. They look expensive. Just need some opinions asap!
You will be fine resurfacing your flywheel if it is in good shape. If you switch to a Single Mass flywheel you will need to change your clutch disk because a SMF needs a sprung disk while a unspring disk is used for DMF.
Single mass flywheel will get rid of that annoying RPM hang that the dual mass flywheel has. So with a single mass flywheel the engine will feel more responsive vs the dual mass. Stick with a heavier steel flywheel, the lighter the flywheel the more gear rattle you will hear.
If you need to talk more about flywheels feel free to PM me.
