Is this foolish?
Old Oct 17, 2011 | 04:22 PM
murdox's Avatar
Default Is this foolish?
Quick Q - I need to replace my tie rod 'ENDS' as told by my mechanic. Actually, he couldn't align my wheels because of the significant amount of play on the wheels.
Is it dumb to JUST replace the outter tie rod? Or should i just go for the whole assembly.
Old Oct 17, 2011 | 04:52 PM
ImTheDevil's Avatar
Just do the outers - inners fail much more rarely.
Old Oct 17, 2011 | 06:21 PM
murdox's Avatar
ECS Tuning - Cart
These are the winners - no?
Old Oct 17, 2011 | 06:24 PM
NHolzschuh's Avatar
you cant link your shopping cart u will have to link the actual part(s).
Old Oct 17, 2011 | 06:55 PM
murdox's Avatar
Old Oct 17, 2011 | 08:21 PM
AudimaniaA4's Avatar
I installed those about a year ago and they work well so far. I noticed a significant improvement in steering. Also, I had to replace mine because there was a visible crack on the rubber and movement on the joint. The cracked tie rod end resulted in up and down movement in the wheel, as opposed to left and right as with a bad wheel bearing. This may help you identify whether its the outer or the inner.
Jun 20, 2012 11:39 AM
calmone
Jan 1, 2011 01:59 PM
