front wheel bearing
Old Apr 11, 2008 | 09:53 PM
vlado182000's Avatar
Default front wheel bearing
how do you know when front wheel bearings are bad????
Old Apr 11, 2008 | 09:56 PM
carlv's Avatar
Default RE: front wheel bearing
when you drive down the road and the front end bobs up and down ^_^
Old Apr 11, 2008 | 10:00 PM
A4speed's Avatar
you'll hear a loud annoying sound (like my roommates gf's voice ) as you go faster.
Old Apr 11, 2008 | 10:10 PM
qUaTtRoA4's Avatar
my front drivers side humms, but It has been bad for over a month and I have put abnout 4k on it without the noise getting much worse....
I will replace in the next month or 2
Old Apr 11, 2008 | 10:15 PM
carlv's Avatar
ok look dude, if you repair it now.. it'll be like 300$ or something if you take it to a shop... if you wait until it sounds worse, it's seriously going to cost you up around a grand cuz more parts will be worn and need to be replaced.. don't put it off!
Old Apr 11, 2008 | 10:21 PM
99A4NOW's Avatar
If your wheel bearing is bad it will make a noise sort of like a "hum" that will change pitch with speed. The sound should also change as you go around a corner at a moderate speed. A quieter noise turning left means a bad left wheel bearing, quieter turning right mean a bad right wheel bearing.
Old Apr 11, 2008 | 10:41 PM
qUaTtRoA4's Avatar
ORIGINAL: carlv
the wheel bearing costs $50, all you need to do is remove your steering knuckle, take it to a machine shop, they press the old bearing out and press the new one in...
should take about an hour to remove the knuckle and an hour to re-install MAX....
So, it'll cost 50$ plus another 20$ for the machine shop to press out/in the bearings....
the whole job should take 3 hours (including drive time to a local shop) and cost you about 70$....
Old Apr 13, 2008 | 08:59 AM
thanks for the help
nlinesk8s
Jun 6, 2014 06:03 PM
blainescycles
Jun 3, 2011 09:51 PM
jetmech
Sep 9, 2010 08:35 PM
flyboy
Sep 7, 2009 10:43 PM
montic
Jan 15, 2006 03:17 AM
