Fuel Leak :(
Hey Guys!
So I found a fuel leak. Actually I smell and see a fuel leak and need help finding where its coming from. I can see fuel that has been dried on the bottom of the fuel tank but the bottom seems like its pretty solid. It really only leaks when its about 3/4 - full tank. But you can definitely smell gasoline outside of my car. Anyone have any tricks to find a fuel leak or am I SOL and have to take it to a stealership or my mechanic.
Thanks
Thanks
There a good chance it's your fuel filter who need to be change. If you didn't change your fuel filter in the past 2 years, check that out .. cheap replacement part .. everytime mine is due to be change, it leak gas ... the filter is near the rear passenger wheel so if you see some leaking in this area, it might be the filter.
Good luck
Good luck
