fuse?
Old Jun 30, 2010 | 02:28 AM
peep's Avatar
Question fuse?
i installed new front lights (two piece) and i put everythkng in and turned the emergency flashers on and it went on for one blink and then just stopped working... the turn signals dont work either, front or back. im guessing this is a fuse of somekind? and where can i find the loxation of this fuse?
thanks!
Old Jun 30, 2010 | 02:30 AM
kriptonik's Avatar
Fuses are located on the left side of the dashboard. When you open the driver's side door, you'll see a plastic panel on the side of the dash. You'll need to take off the panel. Once it's off, you'll see the whole collection of fuses and you can use the guide on the back of the plastic cover to locate which one it is.
Good luck.
Old Jun 30, 2010 | 06:45 PM
peep's Avatar
just checked, all fuses look good. what could be some other problems?
Old Jun 30, 2010 | 07:29 PM
ImTheDevil's Avatar
Failure of the flasher relay is common. It's built into the hazard switch and costs $25ish.
Old Jul 1, 2010 | 02:41 AM
kriptonik's Avatar
^ What he said. It is a common issue for our cars.
velvet jones
Jul 2, 2010 05:09 PM
rodel
Jan 22, 2009 12:25 PM
JcoyA6
Apr 24, 2008 01:30 PM
andrewk24
Mar 24, 2008 07:53 PM
brokenwire
Oct 20, 2005 12:11 AM
